AVIC-F90BT Screen Flickering From Day To Night Mode
By STNC · Jan 08, 2009in Problems/Troubleshooting💬 14 posts👁️ 1,316 views
Posted Jan 08, 2009 · 17:12 UTC#1
Hi Everyone,
I have an AVIC-F90BT installed in a 2007 Scion tC. I put it in around a week ago. Recently, When the headlights have been off, after about 10 or 15 minutes, the screen starts to flicker to night mode, and then back to day mode, and then back again, and it just keeps flickering. When I turn my running lights on it goes to night mode like it should, and then it stops flickering.
Does anyone know what could be causing this? Could this be an overheating warning?
Michael
Posted Jan 18, 2009 · 17:39 UTC#2
bump
Posted Jan 18, 2009 · 17:47 UTC#3
You probably need to put a small resistor between the ill lead and ground. I would try about 1000 ohms, 1/4W and see if that takes care of it.
Posted Jan 18, 2009 · 18:26 UTC#5
Either of those resistors should work fine. You may also be able to get one from Radio Shack for less.
No, it is not to limit the current. It is to cause some current to flow to ground so that the voltage on the ill wire does not float too high. Do not install it in line.
Tie one end of the resistor into the connection where the ill wire from the car meets the ill wire from the AVIC. Both wires will still be connected together and to one leg of the resistor. Connect the other leg of the resistor to a good ground, such as the black wire to the AVIC.
Posted Jan 18, 2009 · 18:51 UTC#6
so kinda like a Y
the top of the y are the two ill
and the bottom is ground
Posted Jan 18, 2009 · 18:58 UTC#7
Yes.
Posted Jan 18, 2009 · 19:00 UTC#8
kk, and this should fix this? is this a common problem?
Posted Jan 24, 2009 · 08:18 UTC#9
and which side of the resistor should I connect what too?
Posted Jan 24, 2009 · 17:11 UTC#10
Resistors are not directional devices. Pick a side, it doesn't matter.
Posted Jan 25, 2009 · 03:16 UTC#11
kk
Posted Feb 14, 2009 · 01:05 UTC#12
Before I go ahead and do this soon, I had an idea on what else could be causing this.
I have a system that draws a large amount of power, often it dims my lights and such, could this be the issue? If I were just to get a bigger battery would that fix this?
Posted Feb 14, 2009 · 02:16 UTC#13
Sounds like you might need a capacitor.
Posted Feb 14, 2009 · 02:18 UTC#14
I already have the big 3, as I've heard capacitors are just bandaids for a system.
