Calculate ETA - Vehicle Type/Speed
By Froggy · Jan 08, 2009in Hacks/Mods💬 5 posts👁️ 1,581 views
Posted Jan 08, 2009 · 19:44 UTC#1
Is there anyone who knows if you can change the vehicle type/speed that is used for calculating the estimated time of arrival?
It seems to me that the ETA is pretty inaccurate. In my case I usually beat the ETA with about 30-45 minuttes on a 2,5 hour trip - and I am not driving that fast :)
On my previous Navigon PNA it was possible to change the vehicle speed used for the calculation and I noticed that there are some variables in sys.txt that maybe could help - I just dont know the options for the variables (and if they have anything to do with the issue). The variables are:
vehicle_type=
slow_car_speed
slow_car_multiplactor
fast_car_speed
fast_car_multiplactor
Posted Jan 12, 2009 · 21:04 UTC#2
Where have you found these variables? They aren't in my sys.txt!?
Posted Jan 12, 2009 · 21:41 UTC#3
Nope - but if you search around in this forum and other IGO8 related forums, you will see that there is lots of possible variables that arent used in the stock sys.txt...
fx.: http://www.gpsunderground.com/forums/showthread.php?t=3029
The trick is to figure out how to use them, and I still have a long way to go :)
Posted Jan 13, 2009 · 14:22 UTC#4
I tried to merge the original iGo-Skin (and its functionality (Avoid, direct TMC-Access etc.)) which comes with the LeetLauncher with the AVIC and I'm done so far except the resolution. I will try to implement the ETA-correction, if it's possible and put the whole thing online. But it could take a while...
Posted Jan 13, 2009 · 16:36 UTC#5
FWIW, I'd rather have an overestimation of the time to get to the destination. It makes me feel better as I see the ETA go down. :wink:
My guess is that the ETA is calculated with very conservative parameters, such as never ever ever exceeding the posted speed limit. The travel times that Google Maps provides is also always longer than what it takes me.
In your case, if the ETA for your 2.5 hour trip is on a highway with a 60 mph speed limit, and you drive 75 mph, you'll get there 30 minutes quicker.
The only two times I've really paid attention to the ETA was on a drive from NJ to Kentucky (12 hours), and another one from NJ to Chicago (14 hours). Both were fairly accurate. I reached my destination in about an hour less time than what the ETA said.
