Trouble Doing Bypass
By anangia69 · Jan 08, 2009in Hacks/Mods💬 5 posts👁️ 1,136 views
Posted Jan 08, 2009 · 22:14 UTC#1
im having some trouble in doing the z1/2/3 bypass... i located "connector 2" and as it should be the bottom four slots are not occupied....i grabbed a ordinary 18 gauge wire to insert into the bottom hole but seem to be having some trouble getting it to stay... just wondering what you guys used to make it stay inside the proper hole....
Posted Jan 08, 2009 · 22:29 UTC#2
You have to remove one the unused wires (mute works well), using a fine jewelers flat screw driver, then reinstall it in the correct location on connector 2.
Posted Jan 08, 2009 · 22:30 UTC#3
well cant you use any wire or it has to be one that was specifically used in the pioneer setup, also i send you a pm garrett.
Posted Jan 08, 2009 · 22:43 UTC#4
You have to use one of the harness wires, as it has the metal "seat" crimped to it that makes the connection. I sent you a pic via PM.
Posted Jan 09, 2009 · 00:30 UTC#5
got it to work, thanks to garrett...
also for anyone who needs further clarifcation this is what the metal "seat" looks like....
/end thread
