Vehicle speed on 08 Mustang (other than PCM VSS)
By hybris1 · Jan 09, 2009in General💬 6 posts👁️ 854 views
Posted Jan 09, 2009 · 04:09 UTC#1
I searched and found the wire on the PCM to tap into for the VSS. My question is why can't I use the "Vehicle Speed" wire that already goes to the stereo for the factory auto volume. (Pin 14 on J1 connector on pinout attached) Is it a different signal. I have searched this forum and mustang forums but can't find the answer.
Shaker500.pdf
Posted Jan 09, 2009 · 06:37 UTC#2
Installed the 90BT in my 08 F-150 using the gray/black pin 14 on main radio harness. Works fine with no issues. Got my info from the F-150 forum. I had the unit out of my 07 GTCS and the harness looked identical.
Posted Jan 09, 2009 · 08:34 UTC#3
the mustang uses a can bus signal for the speed sense so its not in the radio harness. actually in my 07 gt/cs my speed volume never worked on the factory radio. i didnt care much since the radio only stayed in there for a week. on the 08 and up i believe, even the 12+ accessory wire is not there and is controlled by the can bus as well.
Posted Jan 09, 2009 · 15:03 UTC#4
For a buss connection, I would expect a tx/rx connection. This wire is specifically labeled "vehicle speed".
What F150 forum was referenced?
How do we know if the speed sensor input is working?
Thanks for the replies.
Posted Jan 10, 2009 · 01:46 UTC#5
well, its a data connection. the f150 is different as it has illumination and vss in the harness. take my info for what its worth. i install for a living.....
Posted Jan 11, 2009 · 07:25 UTC#6
Your right, pin 14 is not populated on the car. Guess I will be running a wire forward. Thanks everone for you input.
