Does the 700 play m4p files? (itunes)
By CFarSr · Jan 10, 2009in General💬 2 posts👁️ 719 views
Posted Jan 10, 2009 · 14:22 UTC#1
Shot in the dark but does the 700 play m4p files? I've got a few albums that I would love to play on the unit but don't want to bother with the SD card if it wont work.
Also, since itunes just did away with DRM, will I now be able to burn the albums that I purchased before the switch on to a CD so I can listen to them in the CD player or on an SD card?
Grats,
Chris
Posted Jan 10, 2009 · 21:16 UTC#2
You can play aac files that don't have drm on them. If they have drm, you will have to remove it (there are multiple methods available). Note, if they are drm protected, you can still play them through your ipod.
Yes, you can burn anything you (drm protected or not) onto a cd through iTunes and then either play the cd or re-import them back into iTunes and play them through your ipod or sd card.
