i try now more then 6 Days it is not working.(activation TomTom MapDE_AT_CH_and_Eastern_Europe_725)
how its posible to Activate the Map without divice ID. ![]()
i use AVIC Launcher v2.0!!!
Please help me ![]()
thans from Germany
thans from Germany
I have not had a chance to try this yet but this is what some kind folk sent to me.
1. Copy TomTom_Navigator_7.450.9028_repack1.cab onto your PPC and run it to install it.
2. Copy USA_and_Canada_720.1803 and voices to the root directory of your SD Card
3. Launch Tomtom and select the USA_and_Canada map and choose manual activation. Write down the manual activation code "XXXXX XXXXX" This is your device ID.
4. Copy USA_and_Canada-14.meta into folder tt7-stuff
5. Open a command prompt (run->cmd) and navigate to tt7-stuff
6. In the command prompt type:
tt7_keygen.exe "path to *.meta file" "DEVICEID" (NO SPACES IN THE DEVICE ID!)
Example:
tt7_keygen.exe "C:\tt7-stuff" "XXXXXXXXXX"
If successful it should say "OK" and create USA_and_Canada-14.meta.dct inside tt7-stuff
7.Now copy USA_and_Canada-14.meta and USA_and_Canada-14.meta.dct from tt7-stuff into USA_and_Canada_720.1803 overwriting existing files.
Skid the items in RED, I did not do those steps. I put all the files on my SD card in the TOMTOM folder. Then find the file that ends in .BIF and open it up with your notepad. In this file is the DEVICEID. Copy that ID down. Then, using the run command in your windows type in:
example: tt7_keygen.exe "C:\tt7-stuff" "XXXXXXXXXX"
(replace the XXX's with that DEVICEID)
It will give you a new file with a meta.dct on the end. Put that file (which will be located at C:\tt7-stuff) in your maps directory and there you go. If it gives you an error that the activation is not activated (which it did for me), then move the whole map directory to the root (main level of your SD card) outside the TomTom folder and it should work.
