help with werid noise
By mkelias11 · Jan 11, 2009in Problems/Troubleshooting💬 3 posts👁️ 677 views
Posted Jan 11, 2009 · 03:32 UTC#1
ok so i have and f 700 series, with an amp for subs and some Boston acoustics speakers.i used the good RCA and have well well ground, all cables have been routed correctly including i pod. So every time i switch track on the ipod source it makes a weird whistling noise and i will do it in the back ground but gets 30 times louder when i switch tacks, does not do it on cd or fm, and i tried unpluging the usb and using as an av and it doset make the whistling noise. What could it be? by the way i swaped the pioneer cable out this morning thinking it might be a faulty cables but it makes it exactly the same.
Posted Jan 11, 2009 · 04:44 UTC#2
Which speakers does it come from? or is it just the sub?
Is the vehicle running or not?
Posted Jan 11, 2009 · 05:52 UTC#3
no the speakers, usually all 4
