hey guys and gals, i'm Tony. i just got my first avic unit last friday and i cant wait to start playing arround with it! it is my first avic unit i have ever had. its an F700BT. i am planning on installing soon and need some help.
ok, so i am going to do the mute wire bypass and ground it and the parking brake wire with the actual ground wire in the metra harness. but i have some questions.
1)where do i connect the vss (speed wire)? i was told the blue wire on the pcm, is this right?
2)should i use a fixed voltage regulator from radio shack or a resistor to drop the amp turn on signal to 5 volts for the factory amps?
i want to install next weekend, so if i could get some help and build the harness before then, it would save me a lot of headaches and time. and plus, then i can start figuring out the "hacking" thing and get a cool background image after i install the 2.0 firmware update.
thanks
--Tony
