I plan on running two amps, how should I run the remote activation turn-on wire? Should I run one wire from the head unit, then split into two (one for each amp)?
Or should I run a jumper wire from the first amp to the second amp?
thoughts guys?
thoughts guys?
Either way should work as well as the other.
I found running the jumper makes for a little cleaner install, but like joegr said, either way will work.
i know at the shop i used to work at we did jumper wires it just looked cleaner to us and one less wire to deal with until you get to the amps.
thanks guys..I appreciate your input and time to help out newbie installers like myself!
