Facotry Rear DVD sync
By dburn077 · Jan 11, 2009in Problems/Troubleshooting💬 4 posts👁️ 774 views
Posted Jan 11, 2009 · 16:53 UTC#1
I just installed a F900BT in a 2007 Suburban. This veh had all the options, Onstar, Bose, rear dvd, and steering wheel controls. I added a rear view cam also.
Right now it seems that everything is working, except for the Rear DVD. It works, but I thought that you were suppose to be able to listen to the radio upfront while the DVD is playing in the rear with the headphone on. The factory system worked that way. I did see in the manual where you can split the rear and front speakers but it was not clear on how to go about that.
I tried to do a search, but I could not find what I was looking for. May I did not word my search right.
I used the PAC-Audio install kit to install the system and integrate with the factory options
Posted Jan 11, 2009 · 17:07 UTC#2
What you wish to do is not possible with the F series, end of story.
Posted Jan 11, 2009 · 18:07 UTC#3
Does the DVD play though the Nav system? I though that is how the manual said it worked. If so then on page 144 of the manual it says that it can be played though the rear output only.....or am I reading this wrong?
Posted Jan 11, 2009 · 18:17 UTC#4
Yes, in that it doesn't mean that you can then play something else through the front speakers.
