rebooting while driving
By Bimmer · Jan 12, 2009in General💬 2 posts👁️ 628 views
Posted Jan 12, 2009 · 18:42 UTC#1
I just installed an F900.With the gps antenna attached the unit starts rebooting everytime while I am driving so I cannot play neither a cd nor hearing the radio etc. but works normally when i stop.When I take off the gps antenna the unit works perfectly even while driving but without the navigation.Did someone come across this problem? I did not attach the speed wire and the reverse signal wire.Could that be the problem?
Thanks for ur help
Posted Jan 12, 2009 · 19:55 UTC#2
Not having VSS or reverse connected is not the problem. I haven't experienced this, but it seems like several others have. I have seen speculation that it is a fault of the internal gyros, and I have seen some comments about corrupted files on the FLASH. You will probably have to send it for repair.
