HOV and Carpool Lanes
By hkgms3 · Jan 13, 2009in Hacks/Mods💬 9 posts👁️ 1,401 views
Posted Jan 13, 2009 · 02:07 UTC#1
Is there any way to make our system using HOV lane routing :?::?:
Posted Jun 24, 2009 · 20:48 UTC#2
Sorry for bring back the old topic.
Currently my HU does not have the option to select "Carpool". My question is if I change the setting_800_480.ui file and modify this line:
Into this line (remove hide):
Will I get the option back?
Posted Jun 24, 2009 · 22:50 UTC#3
In setting.ui it is doing this:
	vScrollingLayer.SET ui_SettingRouteParam
	ui_SettingRouteParamScroll.SETCONTROLS "btn_RPDown" "btn_RPUp"
	runif bHasMapWithCarPool 0 'btnSR_Carpool.hide'
So if your local map does not have car pool info, button still will be hidden.
Posted Jun 25, 2009 · 23:55 UTC#4
I have the F90BT, to add a button on the setting screen, I need to add code to the layer "ui_SettingRoute" only, not the "ui_SettingRoute2", right? This is the setting_800_480.ui by the way.
The code should look somewhat like the one below, right? I will check the var name later.
Posted Jun 26, 2009 · 16:09 UTC#5
Probably, I don't recall which one it was pulling for F90. Look for conditions and compare them with car type selection layer. If there is pedestrian mode (assuming no other mods), it's for F500, otherwise it's for in-dash units.
Posted Jun 26, 2009 · 16:38 UTC#6
Thank you for the pointer.
Posted Jun 26, 2009 · 16:55 UTC#7
You're welcome.
setting.ui controls which of the route screens shows, look for 746_init and 749_init scripts...
Posted Jun 28, 2009 · 02:04 UTC#8
You're welcome.
Added the code and seems like working fine so far; no error yet. I will test the function when I am on the freeways.
Thanks again, BorisM
Posted Jun 28, 2009 · 18:14 UTC#9
You're welcome. The real test will be if it actually sends you to HOV lanes properly...
