chopped up wiring harness (D1)
By hailtoby · Jan 13, 2009in Problems/Troubleshooting💬 3 posts👁️ 638 views
Posted Jan 13, 2009 · 23:43 UTC#1
I bought a used D1 and the wiring harness is spliced like crazy and I am trying to put it back together, which shouldnt be hard, but... The confusing bit is the yellow power and the ground.
The manual shows the yellow lead going into a box and then into the inline fuse. IT also shows the ground lead going to a terminal and also into the box where the yellow lead exits.
This should be easy enough, but there is an extra lead going to the box. IT is right next to the ground lead, where you would pllug the bypass wire. This extra lead goes into the box at the same spot as the power lead.
The manual only shows the power lead going to the box. I would assume that this extra wire was some sort of bypass, but I dont think I can open the box up.
Anyone have any idea what this extra lead is?
Posted Jan 14, 2009 · 00:54 UTC#2
Sounds to me like you got a hot D1, hey anybody out there had their D1 ripped off lately ?
Posted Jan 14, 2009 · 01:05 UTC#3
Im sure its not hot. The guy gave me the original box, owners manual, and an unused cage and trim ring. Not to mention the gps antenna and a rear view camera.
