what is the size i need for my sd card pics to fit screen?
By imracerx · Jan 15, 2009in Problems/Troubleshooting💬 9 posts👁️ 1,352 views
Posted Jan 15, 2009 · 03:55 UTC#1
Hi all, I am new here and know its frustrating to find questions allready answered several times but i cant find it on here. I am trying to fit a slash screen pic from my SD card to fill the whole screen and when i fill the supposed highest size, it will not! it says 2592 1944 to be the largest size at 15 mg but when i do that, it leaves edges on the sides. can someone help? thanks JOHN
Posted Jan 15, 2009 · 12:49 UTC#2
800 pixels wide x 480 pixels high.
Posted Jan 20, 2009 · 02:09 UTC#3
thanks for the tip. not sure why the avic screen states the parameters it does. you actually hel. pioneer doesnt! john
Posted Jan 20, 2009 · 04:11 UTC#4
Well, they give you the maximum size for the pic it can take without choking. The optimal size is the native resolution of the screen which is, as per manual, 800*480...
Posted Jan 20, 2009 · 05:07 UTC#5
Sort of on topic, why are images stretched a little bit?
I loaded my Audi rings logo image and rings are not round.
And yes, image is 800x480 :)
Posted Jan 22, 2009 · 04:47 UTC#6
Good question, I've tried several pics @ 800X480 and all look perfect. If you open the pic in a viewer such as Paint, does it look normal there? If so check the attributes to verify that it's still 800X480. Not sure how the attributes could change, the AVIC unit surley wouldn't do it, but that's the only reason I can think of that would cause the pic to be distorted.
Posted Jan 22, 2009 · 05:03 UTC#7
I've made the image in PS myself and double checked the size multiple times and exported it to .jpg several time with different options.
It's not a big deal at all. It was more curiosity than anything. If it starts annoy me I can just play with sizes and figure out what works.
Posted Jan 25, 2009 · 07:09 UTC#8
If the circles are stretched, maybe you can try making the image a bit wider. 800x480 images look ok to me though.
Posted Jan 25, 2009 · 15:36 UTC#9
Not sure what you are creating your graphics in but check to see what aspect ratio you are using. Are you using 4x3, 16x9, or square pixel? On a computer monitor you should be using square pixel. 4x3 and 16x9 are used for broadcast and video tape graphics.
