in my Dodge Caliber, to the left is the direction driven/temp and under that shows what's on the stereo station wise. now that my 90bt is installed, it just shows AM 530 anyone have any idea what needs to be connected possibly that will make it work again?
new install-now car display shows AM 530 only
Can you change bands? what about FM stations? Do you have HD too? You're talking about the map screen on the bottom right? If you just had it installed, hit the reset button and see if that clears up an install glitch. Then I'd check to see if the antenna cable is still installed. If you hit seek does it go directly back to 530? Sorry about the questions to your questions...
Is it a display in your instrument cluster that shows the station? Since the factory radio isn't hooked up anymore, it may not be possible to change it.
im talking about the car temp display thing way over to the left, shows tire pressure, etc, but on the temp and direction driving, below it just shows AM 530 now where it used to show satellite channel or fm station
I'm going to go out on a limb and say it won't work. Not just for the F90, but I'm not aware of ANY aftermarket stereos that will output data to integrate with a factory dash. They all take data IN (like from steering wheel controls), but not pushing it OUT, which your application would require.
I'm sure someone will be along shortly to tell me if I'm off base..... ![]()
