I don't live in the mountains or a mountainous area, but I've seen a recording of 1250 feet.
What's the max you've seen your unit display?
10,800 feet. I live in Breckenridge, CO. Good luck beating that lol
I live in Montana, Beartooth Pass 10,974 ft.
Are both of your elevations displayed on your navi unit in feet or miles?
Maybe I should of explained what I was getting to with this thread. Pioneer enabled altitude as an option to show, but after a certain height the units would display in miles. It's since been discovered that by changing one line that the unit would display in feet all the time. Some members have enabled this but never reported back whether it worked or not. Since I'm in an area that never displayed in miles I could report accurate results.
It has to absolutely beautiful in the area you two posted. I'll need to get around the country and see what I've missed all these years. Thanks for the input.
I crossed that pass on July 4th several years ago. It snowed 6 inches on top that day. July 4th mind you...
That's not unusual for that to happen, I've seen it snow every month of the summer there. I believe my reading was in feet, unless I was thinking about my old D3. I can't go back up and check for a while, the pass is closed for the winter, and won't open back up until Memorial day.
Sorry to hijack but I'm going boarding in Breck next month. RandomMistakes, how's the powder up there?
Well I guess no one shows their elevation or uses Mav's data.zip.
A simple question and you guys can't even respond. How in the hell are we going to further improve these units if we don't confirmations whether the mods work or not?
Thanks for nothing. If I make it to the mountains, I'll check it myself.
Id help out, but I havent been above 700ft in six months. At least not in a car, or on this continent.
This post/review/submit msg thing sucks!
I use Mavs' mods, as you know, but where I live there's not much chance of getting higher than 250m/475', otherwise I'd be glad to contribute ![]()
WTF
See what I mean!!!!!!!!! I only submitted above msg once............?????
825 feet. Gotta love central TX.
Ok guys, I'm using mav's mods
I live in Bogota, Colombia, South America. 2600 meters above sea level.
As displayed on the unit:
Kilometers/meters: 2 km 597 m
Miles/feet: 1 mi 3141 ft (thats about 8500 ft!!!)
Hope that helps in some way (cause it doesn't for my engine)
Oh, and to confirm I did change the line in the data.zip
We use the metric system here and with the old line on the DATA.zip it always showed up 2.6 Km which sucked, now its more detailed and shows 2Km 576m or whatever the elevation is..... you know what I mean so I guess that's what happened with miles/feet. I'll go down to the country side at about 700 meters in the next few weeks and i'll be glad to see at exactly what elevation will miles turn up (or dissapear), i'm guessing at 1 mile but to be sure I'll check and let you guys know. Sorry not to have reported on this before but I "learned" coding last week and stumbeled into this same problem so with al little more reading I was able to "fix" it. thanks to all of you guys that are making possible this wonderfull mods by showing and teaching usthe ignorant on this subjects how to do all this stuff. I could not have done all the wonderfull things I've made to my unit without the help of the people on this forum.
Ok to answer your question I used your mod and it works great until you reach 5280 ft then it switches to 1 mile + XXXX feet depending on your elevation. I reached 1 mi 2912 ft which if you convert is to feet = 8192 ft.
So yes it will read of only ft until your reach 5280ft then it will read whatever mile your are at plus your current feet.
I took this picture on top of a mountain in Tucson AZ tonight. I decided to take a drive up there after work.
I don't see this as being an issue I believe it is just the way the computer processes the numerical value for elevation by converting the number to the highest or smallest possible value. Depending on how you look at it.
Like I said the mod does whats it's supposed to do which is display feet.
N-S-E-W thank you for your help
Gadget - thanks for the thorough explanation. Now we know that up to a mile the elevation is displayed in feet, after that it's a combination of feet and miles with the miles listed as a whole number. Being in a low elevation area that is something I would not have known or been able to answer.
I'll be in Az for the first week of spring training games. How's the weather been?
Cold in the mornings like 50-65ish then by midday 70-80ish
COLD
what a joke right ![]()
Cold in the mornings like 50-65ish then by midday 70-80ishCOLD
what a joke right
That's absolutely horrible. I guess nobody goes out in the morning when it's ONLY 50 degrees. Winter heating bills must really suck.
1504 ft on Deer Valley Rd going east from 51st ave in Glendale, Az
