no Illumination wire??
By fordman03 · Jan 17, 2009in Hacks/Mods💬 8 posts👁️ 1,474 views
Posted Jan 17, 2009 · 20:30 UTC#1
Hey guys...So I am hooking wires up this morning and I got to look for the Illumination wire and there isnt one on the harness that they gave me?? It even says Illumination.....orange, but on the harness its not there. All there is is a dimmer pos and dimmer neg ??? What I am wondering is if it would be ok to hook the Illumination wire to dimmer pos?
Posted Jan 24, 2009 · 14:10 UTC#2
attach the illm wire to the red switch wire... lights will always be on though but I like that anyways
Posted Mar 11, 2009 · 04:51 UTC#3
you probably have installed by now but hooking up the illumination wire to the red(accesory) wire will keep all the lights on as mentioned wbut will also keep the unit in a state of night mode 24/7. The biggest issue with this is that it will dim the screen all the time. In some areas such as phoenix where it is very bright.... this makes the screen impossibly hard to see during the day. if you have a DMM(digital multi meter) test the dimmer + wire to verify that it sits at ground with lights off and goes to 12V when parking lights are on. This should be the wire you will want to hook the illumination wire up to...not the red wire. :D
Posted Mar 11, 2009 · 06:55 UTC#4
AVIC switches to night mode by time/position, dimmer wire only affects brightness, somewhat...
Posted Mar 11, 2009 · 13:34 UTC#5
It doesn't necessarilly have to go to a factory ILL wire, just a wire that is activated when the parking lights are turned on. Cigarette lighter bulb, exterior parking lights, etc
Posted Mar 12, 2009 · 02:38 UTC#6
illumination positive will work unless you turn off your dash lights at night than hu goes into day mode, don't make it harder for yourself when the wire is right there in front of you.
Posted Mar 12, 2009 · 04:03 UTC#7
ya. which in fords case is the dimmer pos wire on the aftermarket harness
Posted Mar 12, 2009 · 14:32 UTC#8
I wasn't able to find a setting for that... mine definitely switches based on lights. I wish it did not... I have an F-90BT with the update installed. I used to just leave my lights on all the time, as they go on and off with my ignition, and now I can't do that.
