Pioneer Avic-80 DVD Problem
By nymiezer · Sep 30, 2006in Problems/Troubleshooting💬 8 posts👁️ 1,633 views
Posted Sep 30, 2006 · 00:35 UTC#1
Hi, My Avic-80 has developed a weird problem. When I try to set an\ route through the "Adress Search" option, it will come up with the error "Destination does not exist, do you wish to continue? for every adress I enter. The unit can still route through the phone book and my adress contacts, but no through a new adress search? Is there a way to fix this?
Posted Sep 30, 2006 · 01:01 UTC#2
Have you tried changing the region number your in? Might have gotten cchanged somehow. THat or try resetting the unit.
Posted Sep 30, 2006 · 01:07 UTC#3
I have tried both those methods with no success already. What is weird is it can find intersections, just not a fixed address. The locations I have saved in my address book produce routes with no problems, but if I try to type one of those locations in address search, I get the error message does not exist. I can no longer map out new locations through this method and am at a stand still at this point.
Posted Sep 30, 2006 · 01:39 UTC#4
I just did a test. I picked an address in another region, and it worked fine. What would cause my gps to make this error in my current region? Could this disk be damaged?
Posted Sep 30, 2006 · 02:34 UTC#5
It's entirely possible take a look at the bottom of the disc.
Posted Sep 30, 2006 · 17:13 UTC#6
Also, hold the disc up to the light, and lookfor pinholes in the reflective media.
Posted Oct 01, 2006 · 15:30 UTC#7
It was the disk. I created an ISO image of the original disk and then burned the image to a Dual Layer DVD-R. Eveyrthing works perfect again.
Thanks again.
Posted Oct 02, 2006 · 12:50 UTC#8
Kewl.
