data.zip on mac
By chenzie11 · Jan 18, 2009in Hacks/Mods💬 9 posts👁️ 1,449 views
Posted Jan 18, 2009 · 19:08 UTC#1
im trying to do the software bypass but i cant get it to work. I unzip data.zip change to number to 256.0 and copy that data folder back on my sd card so its in the folder along with data.zip. am i supposed to re zip the data folder or am i supposed to change to folder and replace data.zip with data?
Posted Jan 18, 2009 · 22:31 UTC#2
You should just take the data.zip you have and go into it (dont extract) find the file, and make your changes, and save the file. This way you don't have to extract anything. Then replace the data.zip that you have on your nav.
Posted Jan 19, 2009 · 01:30 UTC#3
As far as I know there is no compression tool that will allow you to edit a zipped file without extracting it on a mac. If any one knows of one please let me know
Thanks...
Posted Jan 19, 2009 · 06:17 UTC#4
i have yet to find a way to get into a zipped file without unzipping on my mac
Posted Jan 19, 2009 · 06:54 UTC#5
If you can use an emulation app like Parallels Desktop to run Windows you can explore the DATA.zip and make your changes.
Posted Jan 20, 2009 · 04:01 UTC#6
so until then i cant alter the data.zip file and thus not mod my f90bt?
Posted Jan 20, 2009 · 09:27 UTC#7
You can do what I did. some of the people share there modded files you can down load one of those...
I know it's not the same, but until I bring my self to put windows on my mac It was my only option...
Posted Jan 20, 2009 · 09:31 UTC#8
Use winrar as here you can open data file and add new content in it, push button save and it saves it.
So no extraction is needed ......, i gues that als MAC has winrar?
Posted Jan 20, 2009 · 13:43 UTC#9
There is but only command line. No GUI.
