f90bt v2.0 test mode
By aircrue · Jan 19, 2009in Hacks/Mods💬 3 posts👁️ 1,084 views
Posted Jan 19, 2009 · 14:20 UTC#1
Heya,
I got the f90bt v2.0 for xmas and cannot get it into test mode, I followed the direction for putting the files(MiTACAP, Testmode) on the sd card, and starting the unit. I get the copy file message, and can see the start menu, but when I click on anything I get green bars on the menu items, and it seems to lock up, any ideas?
Posted Jan 19, 2009 · 14:27 UTC#2
did you calibrate your screen before going into test mode? after you do that, click the x in the upper right hand corner after you are in test mode, and then it should work.
Posted Jan 19, 2009 · 16:36 UTC#3
That was it, thanks for the help. Fantastic
