Swapping decks to my wifes rig, now I have a big and small antenna led in my wifes 2000 Toyota Land Cruiser. Is there an adaptor and I can't make the antenna go up even in radio mode. Does someone have an idea on what I'm doing wrong???
2000 Land Cruiser Antenna ???
So I found this on the web:
2000 Toyota Landcruiser Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Black/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Black/Red
Car Stereo Amplifier Location: Right of the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): Yellow
So will my pwr antenna not work? I can't even make my manual switch work either.
