Location Arrow !! HELP
By kromHASaWRX · Sep 30, 2006in Problems/Troubleshooting💬 8 posts👁️ 1,614 views
Posted Sep 30, 2006 · 22:14 UTC#1
:shock: I installed the D1 with the bypass and it works great but my loaction arrow is not straight. I adjust my loaction and make it straight but like the next day and go down the road the arrow will be perpendicular to the road, but it will be straight on the road but not facing the correct direction please help! :(
Posted Sep 30, 2006 · 23:50 UTC#2
Is your vss hooked up? Sounds like your moving before the gps has gotten a lock on the sat signals.
Posted Sep 30, 2006 · 23:52 UTC#3
no.. have not.. i have a 06 WRX and am having a hard time finding the correct wire. :(
Posted Oct 23, 2006 · 01:54 UTC#4
Im having the same problem, i dont have the VSS hooked up but i had a D1 before (now have a D2) and it worked fine without the VSS, the arrow always pointed in the right direction and everything. any ideas???
Posted Oct 23, 2006 · 03:01 UTC#5
Hey man, I just installed the D2 on my STi and all you have to do is remove the two top screws holding the black plastic surround around your gauge cluster, remove the black plastic surround, then remove the three screws holding the gauge cluster on, pull the gauge cluster forward, unhook the very far right wiring harness (there are three and you want the far right one closest to the center console) and tap the dark green with black stripe wire. It was very easy for me to do and when you have your console apart it is very easy to route the wire directly to the Pioneer's wiring harness.
Posted Oct 24, 2006 · 02:24 UTC#6
I think i fixed it, I called pioneer and they actually told me about reseting the learning status and i did that and it worked. I think it was because the previous owner of the D2 had the VSS wire hooked up and it learned how he drove but im just glad to fix it, its probly not as accurate as with the VSS hooked up but i dont know where it is in my car (pontiac g6) so i dont want to bother with it.
Posted Oct 25, 2006 · 01:19 UTC#7
Thats funny....I wonder if the previous owners antenna was turned in a different orientation then your was.....
PS...I thought it was a new unit..... I thought of that the other night but thought it was new so I didn't mention it..... lol
Posted Oct 25, 2006 · 18:19 UTC#8
i had the same problem with an old unit.
So i hook up the VSS wire and problem is now solve
