bluetooth update..... How long does it take?
By Blustang05 · Jan 20, 2009in Problems/Troubleshooting💬 2 posts👁️ 766 views
Posted Jan 20, 2009 · 20:42 UTC#1
Hi guys just tried to updated to v2 which worked great i then tried the BT update but it was taking for ever I finally had to go back to work after 20mins of wait for the BT to update. i went ahead and shut the car off. I tried it again when i got home from scratch redownloaded it a put the fresh copy on the card and i still get the same outcome. any thoughts?
thanks
Posted Jan 21, 2009 · 13:19 UTC#2
Well, it's been a while since I did that update, but I don't remember it taking much longer than 5-10 minutes.
It sounds as though something might be messed up. Others than are more dialed in with this hopefully will chime in, but I guess if it were me, I'd try to re-do the 2.0 update and then try the Bluetooth once more after that. It can't hurt, and might do the trick.
Sorry I couldn't be of more help, but wanted to at least confirm from one other person that it probably shouldn't be taking that long!
Cheers,
Kev
