Bad XM Reception
By s1xsp33d · Jan 21, 2009in XM/Sirius/HD Radio and Traffic Receivers💬 5 posts👁️ 1,954 views
Posted Jan 21, 2009 · 17:00 UTC#1
For some reason my XM drops connection when driving under bridges (short overpasses on the highway), and even some road signs and sometimes even when there is nothing over my car. Do i maybe have a bad antenna, or is there some sort of diagnostics screen on the avic for XM? This is really bothersome and a bit ridiculous IMO. I could understand sitting under a bridge or in a garage, but when there is nothing around me? c'mon. :evil:
Posted Feb 12, 2009 · 19:39 UTC#2
Can you share with us where you have the XM antenna mounted? I find the lower the antenna is to the ground, the greater likelihood there is for signal loss.
As a test perhaps you should attach your antenna to the roof of the car and see if your problem goes away. If it does then you know what your problem is.
Regarding diagnostic screen for the XM radio. I'm afraid I haven't seen one.
Posted Feb 18, 2009 · 11:46 UTC#3
i have the antenna sitting in the front center of my dash.
Posted Feb 18, 2009 · 15:50 UTC#4
It needs to be outside the cabin. I had a similar install in a past car and any time the view to the south was obstructed for more than just a second it would drop out.
Move it to the roof and you'll be set.
Posted May 26, 2009 · 02:46 UTC#5
for anyone who is interested...i had the antenna moved to the trunk lid and reception is a non-issue now.
