Can This Be Done?
By sniper_101 · Jan 21, 2009in Hacks/Mods💬 9 posts👁️ 1,624 views
Posted Jan 21, 2009 · 21:35 UTC#1
I have a question that I haven't found to be asked on here (at least in the F-series board). Is there anyway to add a keypad on initial start-up of the unit? If so can the remote-turn on output be controlled through software within the unit? Is there any of you Guru's could add a primary menu layer/setting to disable/enable the remote turn on lead to act as a ignition lock?
I would love to be able to turn the key to on, have the unit start with a number pad on the screen, enter the 4-digit number and then be able to start my vehicle with the key. Is this in anyway possible on my F700BT?
Thanks guys, just day-dreaming at work again.
Posted Jan 21, 2009 · 21:36 UTC#2
Like in The Transporter? Lol
Posted Jan 21, 2009 · 21:43 UTC#3
I never thought of it like that, but yes. Any idea if that could be done? Although unlikely, it would be a great anti-theft feature.
Posted Jan 21, 2009 · 23:38 UTC#4
I can't see it being done through the avic but I'm sure there's some password piece you can hook up to a relay tied into the starter wire. The avic is in no way tied to your ignition harness, and the only way I can see it ever happening is if someone designs the password interface so when the correct sequence is entered it gives power to a wire not being used by the owner, IE reverse wire or speed sense, etc, which would trigger a relay that allows your starter wire to complete the circuit...but good look with that.
....I want that though lol
Posted Jan 22, 2009 · 02:08 UTC#5
These are available online... But it would not have anything to do with your Avic.
I had a push button start installed in my Porsche because I thought it would be cool... It actually was a PITA. A good old metal key in a lock will almost never fail you... But the first time you are sitting in a parking lot with a hot chica by your side and you enter your 4 secret digits and the car wont start, your gonna wish you still used a key!
PS: I just checked and I cant find it any longer... ABout 6 months ago, I did a google search and found a link from a BMW website. Now all I can find are the fingerprint readers.
Posted Jan 22, 2009 · 02:43 UTC#6
That's why you put an emergency hot chick switch hidden to bypass the password lock when activated lol
Posted Jan 22, 2009 · 02:53 UTC#7
I think you misunderstood, I know the radio wiring is not connected to the ignition-to-starter wiring, only the ignition switch relay, this isn't what I was intending. I meant use a power out already on the unit, like the remote turn on lead, controlling it using software (whatever the keypad would use) to turn that lead on/off. This lead would now trigger the starter relay, just like the "crank" position of a regular ignition/push button start. I think it would be kind of cool, but the flaws would be major hassle without some sort of hidden manual bypass trigger.
I remember that "button sequence ignition lock" thread on Bimmerforums somewhere, I'll take a look for it for fun (I'm an avid member).
I think this clarifies what I meant, but like said, if it is possible, it has potential to be a major disadvantage.
Posted Jan 22, 2009 · 03:45 UTC#8
I just did a Google search for this and you would be AMAZED at what I found... I would be banned if I posted the link!
Posted Jan 22, 2009 · 03:55 UTC#9
PM me the link
