Installed my D3,, but..!
By dozug · Jan 21, 2009in Hacks/Mods💬 4 posts👁️ 2,149 views
Posted Jan 21, 2009 · 21:51 UTC#1
When i use navigation fuction, its really slow.. i mean i was turning the corner and the map is still on the straight line and after i made the turn compeletely, map shows im turning right now.. i almost have full signal,,
Also, i can not access to the "Guide View" and "Route View" I didnt install them, I went to audio store and let them install.. I gues they forgot some wires.. Illumination is off(they didnt install)
Also, every time i power on, thers pop up message saying Parking blake wire is installed incorrectly,,, so i have to push OK everytime it turns on..
Can you guys help me fixing all of them??
Thank you
Posted Jan 22, 2009 · 01:34 UTC#2
Have you tried programming in a route and then trying Guide and Route view?
Posted Jan 22, 2009 · 01:36 UTC#3
yes,, i was navigating and i couldnt select them...
Posted Jan 24, 2009 · 04:01 UTC#4
If the parking brake wire isn't installed correctly, or the bypass isn't performed, you can't select other map views while driving, right? That could explain why you cannot select another map mode.
Also, no need to cross-post your questions...keep it all in one section. Thanks.
