2006 Ford F150 backup camera cable routing
By JBone · Jan 22, 2009in Vehicle Specific Wiring💬 4 posts👁️ 3,850 views
Posted Jan 22, 2009 · 05:42 UTC#1
Hi all,
I was wondering if anyone has installed a backup camera on a Ford F150. Any bumps in the road? Where did you come in with the cable?
On another note, how does everyone feel about a 2.4Ghz wireless back up camera? Any input is appreciated.
-JBone
Posted Jan 22, 2009 · 07:25 UTC#2
go with a wired one. when i had my 06 f150, i ran it through the large grommet that is above the gas/brake pedal. if you look near the brake booster, in the engine compartment, you will see it. i ran it along the frame rails and ziptied it to the factory wiring. get a nice creeper and you'll be able to do it fine. little tip.....wear safety goggles!! i offroaded in my f150 a lot so a lot of dirt kept falling in my face...the googles worked!
Posted Jan 22, 2009 · 17:25 UTC#3
Thanks for your reply!
Is there an ACC wire near the camera? How did you power it?
Posted Jan 22, 2009 · 18:20 UTC#4
i ran a power wire with the rca and powered it with the acc from behind the radio. just tape them together and then run both wires in split loom
