Will the XDV-P6 work with the d3 or f900bt?
By RANDY350Z · Jan 22, 2009in General💬 5 posts👁️ 694 views
Posted Jan 22, 2009 · 07:33 UTC#1
I am interested in purchasing the dvd changer!
Posted Jan 22, 2009 · 08:14 UTC#2
You will have to run it in standalone mode and run it in through the A/V input. All controls done from the remote
Posted Jan 22, 2009 · 23:33 UTC#3
Can the ip bus be used for the music changer part? And will the remote function work if the changer is in the back part of the car? Thanks!
Posted Jan 23, 2009 · 00:59 UTC#4
Nope, the F series isn't compatible with either of the Pioneer CD changers or the DVD changer which is the main gripe I have with the F series. I miss my CD changer. The CD changer and I believe the DVD changer are compatible with the D3
Posted Feb 12, 2009 · 17:56 UTC#5
I found that you can connect it to the D3 w/ ip bus aslong as you also connect the yellow vid input.....
I may try getting a p9 also!
