Before you say search, i did see the other posts kind of like this one. Didnt see an answer so here it is again.
I bought an AVIC-D3. I had Sirius with the stock head unit. I found the stock reciever and followed the cord to the exterior antenna to be sure. The antenna connection looks kind of like a small cable tv cable (single pin). I also bought the SC-C1 unit to hook up the Sirius to the D3. The antenna input on the unit is an 8 pin connection though. So my question is, do I need the CD-SB10 to connect my stock antenna up to the SC-C1 box? I attached pictures to show what i mean. It looks like the CD-SB10 is kind of a cable converter from the 8 pin to the single cable tv like cable.
The first picture shows the 8 pin antenna input connection for the SC-C1.
The second picture shows My stock tuner and the cable coming from the antenna.
The third picture shows the CD-SB10 unit. The red cirlce shows the antenna that comes with the kit which has a similar looking connection to my stock antenna cable and the green circle arrows show the 8 pin connector that is on the SC-C1.
