F90BT VSS wire - what's the point?
By EezyAl · Jan 23, 2009in General💬 6 posts👁️ 1,091 views
Posted Jan 23, 2009 · 16:59 UTC#1
Just curious, but what does the VSS wire do for our units, besides supposedly helping the GPS accuracy? The speed display on the map is entirely contingent on the GPS signal, as it shows 0 mph whenever I haven't acquired a signal... It possibly affects the variable volume of the voice, but I kinda doubt it, for the same reason as above...
Posted Jan 23, 2009 · 17:02 UTC#2
Navigation in tunnels and alike, as the manual explains...
Posted Jan 23, 2009 · 17:05 UTC#3
Yea, I know what the manual says... Hence the 'besides helping GPS accuracy' that you quoted... Just curious if there's any other point to it, for future reference...
Posted Jan 23, 2009 · 17:06 UTC#4
No other point really... OTOH it does not take that much effort to hook it up when installing, so might as well do it...
Posted Jan 23, 2009 · 17:16 UTC#5
Yea it probably took me 15-20 minutes since I had to get behind my gauge pod... Which is probably much easier than in other cars... Meh... If I have to do it again I think I'll just skip that step... It would really tick me off if I were to scratch the pod or (god forbid) break something...
Posted Jan 24, 2009 · 07:56 UTC#6
i have the f700 (which does not use the vss wire) and the nav is perfect. its extremely accurate. when using route guidance, it takes me to EXACTLY where i need to be every time, with no vss wire.
