IGO 8.3.1 NORTH AMERICA ON AVIC S1, S2
By alizee · Jan 24, 2009in AVIC-S1💬 7 posts👁️ 7,164 views
Posted Jan 24, 2009 · 13:35 UTC#1
I've made a SD card with the newest maps of NORTH AMERICA :D , all you have to do is just put the SD card when navigation is OFF and then turn it ON.
All is working great, without and "unlocking", you don't lose your warranty in this way! - because you only edit your SD card, not main memory on the unit!
I can put all of that, on the NET to download.
I expect small fee for my time, try to understand that. Write PM or e-mail [email protected]
Posted Jan 26, 2009 · 04:43 UTC#2
This sounds like a great idea. I am curious though on future updates, how do we keep current with the updates?
Also just curious what you charge for this service.
If you prefer you can IM me.
Posted Jan 28, 2009 · 08:38 UTC#3
The future update you will be able to download from my server i will try to colect it and share it with you, i work in gps service so i have got access to most of the gps software. :idea:
:arrow: Write to [email protected]
Polish site: http://www.gps.pol.pl
English: UNDER CONSTRCUTION
Posted Feb 22, 2009 · 01:24 UTC#4
If u download from the torrents it works perfectly, just use the ce unlocker and the igo8 no probs...
Posted Mar 01, 2009 · 20:26 UTC#5
OK :) I got MIO v3.3 and IGO8.3.1 running on my Avic S1 with free solution :wink: You can download all the files you need on the net and spend som time :wink: But I will make it easyer for you guys :wink: took me few hours to resolve that problem with Avic :? After you load all files to SD card make sure to delete SYS.txt , I had errors with it all the time and tryed different solutions until I removed it and then it worked fine :wink:
Good luck !!!
Posted Mar 04, 2009 · 11:16 UTC#6
DJEurobit u need the sys.txt file!!! Is yours GPS working correctly? I don't know if you have checked my instructions but you have to change the band in sys.txt
