I finished the install of my AVIC-Z3 today. I used wire harness adapters and I am sure all the wires are correct. I also did the modification so that the nav/dvd viewing works while driving. Everything works very well except there is no audio what-so-ever. I am perplexed as to what I can do to get the audio to work. I installed the deck in my 1997 Infiniti qx4. Is there some sort of a stock amp that is causing the audio not to work? I hooked up the power antenna wire to my power antenna and that works well. Right now Im not even getting a hissing noise out of the speakers. Absolutely nothing. Any help would be greatly appreciated.
PS. The only wires that I don't have hooked up right now are the dimmer wires and the remote wires.
