Does the F90BT display traffic flow information? If so how?
By corpun · Jan 25, 2009in General💬 10 posts👁️ 1,434 views
Posted Jan 25, 2009 · 19:47 UTC#1
I've done quite a bit of searching but either I'm missing the obvious answer or its not that easy to find.
I'm trying to figure out if/how the F90 displays traffic flow information. All the promo stuff I've seen only shows incident reports and slowdown reports in text.
I live in the SF bay area so heavy traffic is regular but often not predictable. The best part of the OEM nav system I have now is that it displays traffic flow speed as colored lines alongside the freeway. This information is always up if you have it turned on, you don't need to plan a route to see it.
This is more or less what it looks like (different nav system but similar traffic flow display):
http://g-ecx.images-amazon.com/images/G ... icAnim.gif
Does the F90BT do something similar? If so can someone post some pictures of what it looks like?
Posted Jan 27, 2009 · 07:55 UTC#2
Seriously, no-one knows the answer to this?
Posted Jan 27, 2009 · 19:37 UTC#3
No it doesn't. Only older pioneer models that used XM navtraffic could do it
Posted Jan 27, 2009 · 20:17 UTC#4
I am quite positive I've seen mine coloring roads in yellow and red, in addition to little traffic icons...
Posted Jan 27, 2009 · 21:21 UTC#5
Maybe its just the freeways I take but no flow here. Incidents and re-routing work though
Posted Jan 27, 2009 · 21:31 UTC#6
Interesting... I'll take another look at it...
Posted Jan 28, 2009 · 07:47 UTC#7
Thanks for the responses.
It doesnt have to be colored lines on the map, just some way of seeing traffic flow info w/out having to plan a route or scroll through the local traffic updates.
From your responses it sounds like there is something there that shows you flow info on the fly.
Posted Jan 28, 2009 · 14:09 UTC#8
You have to subscribe to MSN Direct and it will show you the colors. Yellow and Red. It could be city dependant though. I live in Chicago.
Posted Jan 28, 2009 · 14:12 UTC#9
I'm pretty sure it's area specific/dependent.
Just like maps app in iPhone never has my town traffic info.
Posted Jan 28, 2009 · 18:10 UTC#10
Nothing on mine without a route plotted. I'll try it using the nav on the way home
