I was hoping for a little information. I am a novice when it comes to installing sound systems. My car, a 2002 mustang, with the mach 460 sound system, has 4 tweeters, and 4 subs (attached to two amps). I intend to hook the amplified outputs, with high pass filters, to the tweeters, and the non-amplified front/rear outputs to my Amps/Subs.
In the manual it says that the high pass filter can be set to front or rear speakers. Is it referring to the amplified or non amplified outputs? Or is it really dependant on whether the output is designated front/rear?
Basically, what specific outputs does the high pass filter apply to?
Apologies if this is an obvious question, I have searched for awhile and cannot find the info. Any help would be greatly appreciated.
