Bluetooth 3.3 update
By uberGTI · Jan 26, 2009in Problems/Troubleshooting💬 24 posts👁️ 12,639 views
Posted Jan 26, 2009 · 21:43 UTC#1
I've tried searching the forum and Google without luck. Can someone help me out and point me in the direction of where I can download the latest Bluetooth software update for the F90BT? Should I be searching Parrot's website?
Posted Jan 26, 2009 · 21:58 UTC#2
All you should have to do is follow this link: http://www.pioneerelectronics.com/PUSA/Support/Navigation/AVIC+F-Series+Firmware+Update+Download
Follow the directions closely and you should be all set.
Posted Jan 26, 2009 · 22:06 UTC#4
I swear I looked on Pioneer's site and must not have scrolled down past the main firmware update for the unit. Thanks for the help.
Posted Jan 27, 2009 · 13:15 UTC#5
Is it safe to say this is part of the 2.0 upgrade? Thanks!
Posted Jan 27, 2009 · 13:21 UTC#6
Sort of............ the v2.0 and bluetooth updates are seperate downloads, although what I did was install v2.0 first and then separately install the bluetooth. Had no probs at all.
Posted Jan 27, 2009 · 13:21 UTC#7
Posted Feb 07, 2009 · 19:58 UTC#8
The update should be listed for download on pioneer's website.
Posted Feb 08, 2009 · 13:57 UTC#9
Help me uuderstand this, Just because my 700bt came with the 2.0 firmware upgrade doesnt mean my bluetooth is upgraded to 3.3,
Do I need to upgrade the bluetooth anyway? I am having trouble with my samsung r470 (TWOSTEP). Any help would be appreciated, thanks in advance
Posted Feb 10, 2009 · 14:17 UTC#10
Yup, you should upgrade BT to v3.3
Posted Feb 10, 2009 · 14:52 UTC#11
Is there anywhere in the GUI to check which version you are running?
Like you can check for v2.0.
EDIT:
is this referring to current version installed?
Posted Feb 10, 2009 · 21:06 UTC#12
Yes it is - your screen should display > Version: HW100-SW330 RC3 <
if it's a Euro model that is.
The Software Update tab is for initiating the actual update once your SD card is inserted.
Posted Feb 11, 2009 · 01:26 UTC#13
can someone post the the newest version for the U.S. model...is this it: Version: HW100-SW290 RC3
Posted Feb 15, 2009 · 06:32 UTC#14
According to the Pioneer website the newest BT version number is HW100-SW330 RC3.
Here is the link again. If you scroll almost to the bottom of the page the BT update version number is listed.
Posted Feb 20, 2009 · 08:10 UTC#15
how is it better?
Posted Feb 25, 2009 · 01:05 UTC#16
how is it better?
+1
Is the only way it's better due to the fact that it allows IPHONE integration?
Posted Feb 25, 2009 · 03:59 UTC#17
The Bluetooth Update with 2.0 was worse with my iPhone 3G so I went back to the previous version.
Posted Feb 25, 2009 · 12:35 UTC#18
When you say 'worse', what do you mean? Performance? Clarity? Compatibility?
So far my Curve is working great on it, so not sure I wanna do the update, unless there is another reason to do it that I'm not aware of...
Posted Feb 26, 2009 · 05:27 UTC#19
For us it made a huge difference with our Iphones. We can now download our entire address book without the f700-bt rebooting. Make sure you update the bluetooth after the Firmware update though.
Posted Feb 26, 2009 · 05:50 UTC#20
Both of my LG phones, a Chocolate 3 and enV2 worked perfectly with the 3.3 update. I updated the firmware before I ever paired the phone though so I'm not sure if it made a difference or not.
Posted Feb 26, 2009 · 21:27 UTC#21
so i should go into the setting on the unit and that will tell me what version i have before i try to update it
Posted Mar 02, 2009 · 10:04 UTC#22
yes you should
Posted Mar 21, 2011 · 19:24 UTC#23
Can I update F900 EU version with HW100-SW330 RC3?
Posted May 29, 2016 · 05:33 UTC#24
none of these links work - please can someone send me the right link for the v3.3 bluetooth update ?
