Just recently installed a F90.....wondering if anyone cares to share equalizer settings for optimum sound quality...
Equalizer Settings
That's kind of a hard question to answer... each car has it's own acoustics and everyone has different equipment from factory to custom installs with multiple amps, not to mention that we all have different tastes, what sounds good to me may not sound to good to you. The best thing is going to be the old try and see method.
Gruvncubn nailed it with his response. You're best bet is to learn what each aspect of the EQ does, either by reading about it, or preferably fiddling with the EQ and listen as to how each setting changes the sound. Only you can make it an optimum sound for your own ear.
I would also suggest listening to a variety of music while making adjustments.
Flat!!
I guess you guys are right....it is something that I will need to sit down and spend some time on. Whats the best way to do it??? Pick a good song and have it continue to play while adjusting the equalizer settings.....I have a Acura EL with HERTZ speakers all around and 2 pheonix gold amps...sounds good right now but I know I could get more out of it. I may have to adjust the gains and settings on the amps also.....
thanks for the responses
Caveman Captain
