Okay okay maybe I should've searched first but I need to ask y'all. Has anybody had any luck on pairing the Blackberry Storm with their D3 BT systems??? I dunno if its the new 2008 map upgrade but I notice ever since I upgraded the system its really hard to pair phones with the D3 BT I just been havin mad trouble. Not sure if the D3 BT can be paired with the new BT versions. Anybody?
Paring Blackberry Storm with D3 BT
Download the JetWare Mobile software to your phone. http://www.jetwaremobile.com
Run the program once.
Remove the program from your phone.
Then try to connect normally. It appears to rewrite a registry file in the phone and allows it to connect downward to the BT that is on the AVIC.
Were you having the same issue before you upgraded to the 2008 map? If you didn't then it might have been the upgrade.
Well problem solved. I had to reset the BT device and install a program called BlueFTP into my BlackBerry Storm and I had NO issues transferring my contacts over. I guess I walked around Telus's blocking system... As for the problem before updating, I was apple to connect with my LG shine but it would disconnect and re-connect at times. Sometimes not even connect at all. Or it will show its connected but when I dialed a number u wouldn't hear it from the car speakers at all.
Question about Jetware. I was always curious on if this support the BlackBerry Storm or no???
My storm connected first try. I have the 2008 maps as well. The one thing it won't do, is transfer contacts. I'm gonna try the blueftp thing and see if that works.
My Storm also connects fine but I am in the process of downloading the new maps. Just wish I could get my contacts over to the unit.
I have installed the BlueFTP and all works with me. Transferred my contacts over. But what I have also noticed is when u go to ur BT menu on ur BB and select Device Properties. Scroll down to SERVICES and then do a Refresh Service List and u should see things change. If u installed the BlueFTP and eanbled it you should see OPP, OBEX or Object Push and shit will transfer.
What will work fo an LG voyager, I can't do BT audio?
where did u find that BT app. for the bb storm ??? Also where can i find apps for the storm besides the BT apps..
Okay well I found the site of the program on where I found it. It it also recommends you to download it from your phone.
http://www.getjar.com/products/16752/BluetoothFileTransferOBEXFTP
I cannot get the BlueFTP app to download to my Storm. It says "Download failed". The details says "909 Application authentication failure". It says it is downloading v.1.30. I also tried downloading to pc, but BlackBerry desktop manager will not recognize .jad files. How did you get this installed. Thanks in advance.
I upgraded my storm to v.109 and the contacts transferred over on the first try. BT audio has always worked for me.
What about bluetooth avrc audio video remote control? for me this seems to be hit or miss . . . works half the time, and doesn't work half the time . . .
