i have finish installing the F90BT unit on my 1998 Honda Accord 4DS. I was testing it out before i close everything back up. While i perform some tests, i notice the following:
1. While on "Park", my unit will not let me operate the navi or dvd UNLESS i turn the headlights dim lights off! Does this have to do with the illumination connection at the harness? (orange wire on the unit). I dont know if i tapped the correct "Park" wire (red/black coming out of the shift gear). or should i ground the unit "Park" wire to the car metal body (bypassing).
2. i connected the wire for the VSS signal to the "Blue/White" wire at the fuse box on the 3-pin connector. But i've been reading that the correct "Blue/White" wire is at the passenger side for the 1998 Honda Accord. help!
i hoping to finish installation by tomorrow. Any help will be appreciated. thanks.
Also, i want to install my mic in the dash by drilling into it and use a grommet for a cleaner look. Has anyone try doing the same? I will let you know if im successful in finding one that fits.
thanks everyone!!
