im having a hard time with one of the steps.. specifically the second part of this one: Connect the SWI-PS 's Green wire to pin 11 (dk. blue) in connector 1 of the above connector. Connect pin 14 (white/black) in connector 2 to +12v accessory. im installing this on an 07 cobalt SS.. now im guessing i have to tap pin 14 to a 12v acc wire correct? does it have to be constant or switched? and also, i have to use the gmos lan 4 harness if it matters. this just doesnt make any sense to me because your not tapping the 12v into the pac module so how is it going to work?
Posted Jan 30, 2009 · 04:28 UTC#1
