this is probably a stupid question, i just got this HU installed, but i cant figure out how to turn off the damn repeat. only thing i can do is turn on shuffle to avoid it repeating..anyone know how i turn this repeat off
turn off repeat on f90bt?
Hey Man,
did you find a solution? I just got one installed and it is driving me crazy that I can't turn off the repeat. I have a bad feeling I am stuck.
I don't know what source you are using when you want to change the repeat function, but in general to change the repeat function you need to tap the word "Func" and then tap the "Repeat" button until it changes to the repeat mode you want.
mines the same way. all it will change to is either repeat or or song. i just put on shuffle and nothing repeats
I took a look at mine and toggled the repeat when on the ipod source. It did not let me turn the repeat off. Very odd. It's not that big of a deal to me, but Pioneer should fix that and add the option to turn the repeat off.
I have found that I can not toggle between repeat and shuffle from the f90. If I disconnect the Ipod and manually change to shuffle from the Ipod it works fine. You may want to try and do the some to turn off repeat.
I'm new at this and know just enough to be dangerous. My F90 seemed stuck in repeat and I checked the iPod, it was set on repeat. I turned it off and the repeat stopped. One would think the 90 would control that, but didn't seem to. Anyway it does not repeat now. Go figure.
Now, if they'd just update the maps and make the screen a bit brighter..........Oh well............
Tom
