If it resets at 16mph, what happens at 88mph?
My guess is something with the bypass code is causing it to reset.
ddonnik17, I have absolutely no idea how the AVIC could set off your radar detector. I would be more inclined to think the detector is just picking up airport/weather/automatic door scatter. Also, make sure your phone contact list does not have spaces or non-alphabetic characters, that will prevent contacts from working.
hey, im pretty sure its not airport/weather/or door scatters since they don't go off Ka band since that is 99% the police. also, ive had the radar for 3 years now and now where it goes off and where not. plus i then disconnected the unit, and drove the same route again, and it didn't go off even once.
what i think it might be is....when i had the avic d1, i had a whole bunch of aluminum insulation tape covering the heat box (since i got a e46 bmw, i had to custom cut the heat box to make room), but i also had black guerilla duc tape covering it.
this time, i re-did the heat box, but didn't put duc tape over it, and left it at the aluminum insulation tape. maybe that along w/ some magnetism in the unit could trigger the radar, i will try to cover it up w/ non metal tape.
that should work, right???
also, the bluetooth, its not that i can't transfer contacts, its that my unit won't pick up ANY bluetooth signal. i tried 4 diff. phones, and they even detect each other while im in the car, but the unit doesn't get any of them.
why?
