Hey AVIC411 peps, i wanted to extend my thanks to those of you who helped me along the way by answering some noob questions (stupid VSS signal wire!!)
Below are some pics showing the finish installation. I was able to find a grommet that fits the microphone and used it to flush the mic to the dash. It looks factory! take a lookie.
My Tim arrives today (hopefully) and that should complement the finish.
MODing tip:
copy and paste is a thing of the past!! i hated copy and pasting the necessary modded files to my unit. so i was able to find away around that to simply drag and drop!!
1. Go to the folder you want to paste a folder/file in.
2. Go to "Start" --> "Run"
3. Click on "Browse" To display all file type, select the down arrow and select "All" where it says ".exe"
4. Browse to the SD card for the desired folder/file and just drag and drop using your stylus!!
also, i was having problems with the top menu of WinCE. It had to do with the calibration of the screen. which you can do after booting to WinCE.
1. Go to "Start" --> Control Panel --> Stylus. And select the tab that says calibration
don't know if it has already been mentioned in other threads. if so, sorry for the double posting...
Car Info:
1998 Honda Accord LX 4D Sedan
