F90bt vs D3- Which one should I get?
By mjar01 · Feb 06, 2009in General💬 14 posts👁️ 1,403 views
Posted Feb 06, 2009 · 02:20 UTC#1
I can get the D3 for $300 gently used, no warranty, and the F90bt for $680, 2 yr warranty, and install kits.
I basically want the unit for GPS, Ipod playback, movie/video options (AVI files).
What would be the best unit to go for?
Thanks!!
Posted Feb 06, 2009 · 03:21 UTC#2
im thinking about selling my f90bt and getting the D3. the f90bt is NOT accurate enough like the D1 (thats what I had until 4 days ago). the car arrow passes intersections before you do it!
also, the f90bt causes my radar passport escort 8500 to go off Ka band EVERY 10-15 seconds. on top of that, it won't connect to bluetooth. i tried a motorola krazr, razr, blackberry curve, and blackberry pearl. NONE connect!
i am so pissed about this unit like crazy! either i have a major defective unit, or this unit just sucks.
overall, go with the D3!!
Posted Feb 06, 2009 · 03:28 UTC#3
I replaced my D3 with the 900 and I would not go back. The D3 is a nice unit... but there were 3 additional boxes that I needed to have installed under the dash to make it do what the 900 does by itself.
I think that the 900 is just as accurate as the D3 for navigation, and I LOVE that I am able to change maps, add 3D buildings and modify the GUI on the 900. NONE of this was possible on the D3.
Posted Feb 06, 2009 · 03:30 UTC#4
Im amazed you didnt complain about the slow boot times or the other typical issues. None of the issues you seem to have are common. Maybe the person who installed your unit did a poor job... or maybe your unit is defective.
Posted Feb 06, 2009 · 03:54 UTC#5
f90 all the way
Posted Feb 06, 2009 · 04:05 UTC#6
LOL, yeah the boot time is fine with me, im not in a rush! plus i learned here that this is common, so therefore no complaining.
regarding the install, i did it myself, but i know what I am doing since i installed the d1, and the d3 before numerous times in my car or in others. installation was fine...i hope.
i have NO idea why it triggers my radar. first i thought it was a lot of cops around all the sudden, but then even on back roads and in MY GARAGE...then i took out the unit, unplugged it, and drove the same roads as before, and NOT once did it go off!
i just don't know what to do, im so depressed! i was sooooo happy gettin it and now all this! the bluetooth won't work, the gps isn't accurate, the 2D map never faces forward(i just don't know how to set it). and the radar issue!
dammit...
Posted Feb 06, 2009 · 04:07 UTC#7
Can you have custom background displayed for the f90bt.
Also, can you change the lighting on the buttons and display? I have an orange display in the car and would like it to match.
Posted Feb 06, 2009 · 04:12 UTC#8
yes and yes and yes to all your questions....
Posted Feb 06, 2009 · 04:20 UTC#9
thanks for the answers.
i read that the D3 runs the navi off a disc? so in order to use navi disc must be in?
BUT the ipod works correct? (while navi disc in)
ALSO... does it have AVI usb support if i want to plug in my usb flash drive with avi movies on it.
Posted Feb 06, 2009 · 04:27 UTC#10
lets see...yes the d3 runs off a disc, however, it loads the route/destination that you need, and then you can remove it, so it doesn't have to be technically in.
i believe the ipod should work while the disc is in, i don't see why not, but double check that with someone.
regarding the avi usb support....no clue...
Posted Feb 06, 2009 · 04:29 UTC#11
still deciding on what to get. i like the fact each one can be customized to some extent. i really will be using ipod the most, radio, navigation, movies... bluetooth not as much..hmm
thanks for the info ddon!
Posted Feb 06, 2009 · 04:33 UTC#12
no problem man, anytime. im sure you will make the right decision, i just think my f90bt is just defective and thats why it does these things....
Posted Feb 06, 2009 · 04:45 UTC#13
its usually the cost that is the deciding factor, and if i can get the D3 for $400 installed, it's pretty tempting..
for the custom backgrounds on the f90bt... is it the main screen (destination/contacts...) or is it within the source function??
i saw a few vids on youtube on the D3 and the custom background was for all the options.
Posted Feb 06, 2009 · 12:54 UTC#14
sorry...i haven't had the f90bt long enough to figure that out, only 5 days. but you can find that answer here in the forum. im pretty sure you can modify the 90 as much as you want since its running on windows
