Hey everyone. I have an Avic f900, did the wire bypass. but now, the reverse cam doesent turn on when i put the car into reverse. any suggestions? or does it the wire bypass make the automatic reverse cam go by by?
Thanks in advance
Thanks in advance
you either did something wrong or disconnected a wire.. how did you do your bypass.. the backup cam works with bypass
I did the 2 wire, and connected the cam power to my reverse light, soo when i go into reverse, it turns on, i think the 2 wire involved the yellow mute wire and the green with black tracer.( i think ) the speed wire
if i remember correctly, i moved the yellow wire between the 2 black wires, and then cut the green, and grounded them both.
