VSS wire on '06 Toyota Tacoma
By TLud · Oct 04, 2006in Vehicle Specific Wiring💬 5 posts👁️ 2,967 views
Posted Oct 04, 2006 · 15:26 UTC#1
Can anyone tell me where to find the VSS wire on an '06 Toyota Tacoma? Thanks.
Posted Oct 04, 2006 · 21:35 UTC#2
Speed Sense purple/white fuse box, black 13 pin plug, pin 5
Notes: Also found at the ECM behind the glove box, second plug from the bottom, pin 8.
Reverse Light red/white + driver kick, gray 12 pin plug, pin 1
Posted Oct 04, 2006 · 23:57 UTC#3
Thanks! I found a wiring diagram for my truck, but wanted to make sure I was pulling the right wires. This is my first time installing anything on this scale, and I don't want to make an expensive mistake.
Posted Nov 09, 2006 · 22:54 UTC#4
Tlud where did you get the wiring diagram for the Tacoma My girlfriend has one and I needed the vss(which i have now) but the rest of the wiring would be good to have too. Thanks
Posted Nov 09, 2006 · 22:57 UTC#5
Wiring diagrams plus anything else you could possibly want to know about the Tacoma:
http://www.markass.com/toyotanation/
