help please
By 393stroker · Feb 07, 2009in Problems/Troubleshooting💬 22 posts👁️ 3,699 views
Posted Feb 07, 2009 · 19:44 UTC#1
i need the nav. disc. the guy i got my unit from gave me a burned disc and don't know if it's anygood or not. i can't put in diff. addresses in my n2 unit.
Posted Feb 08, 2009 · 17:43 UTC#2
will the avic n2 work without the hide away unit to play cds?
Posted Feb 08, 2009 · 20:01 UTC#3
No, it won't do anything without the hideaway
Posted Feb 09, 2009 · 03:21 UTC#4
i just hooked up my n2 and when i drive it shows that i'm still at starting point. can anyone tell me what i need to do to fix it? oh, something comes up and says that the parking brake isn't ground right or something. thanks
Posted Feb 12, 2009 · 03:23 UTC#5
sounds like you need to bypass it for starters, search for the sticky on bypassing N-2, next you need to ground out that wire that is supposed to go to your parking brake (orange if I remember), you also need to find out where your VSS (vehicle speed sensor) is located on your car/truck, there is also stickies on that as well, and connect the VSS wire (pinks I thinks) and then make sure you have your gps antenna hooked up, and then you should be all set as long as everything else is hooked up right....hope this helps
Posted Feb 12, 2009 · 04:33 UTC#6
i have the antenna is hooked up and on top of the dash. the guy i got it from alredy did the bypass on it but i don't have the vss wire with the unit or the speed wire. i have parking brake wire ground.
Posted Feb 12, 2009 · 06:32 UTC#7
Is the antenna on something metal?
Posted Feb 12, 2009 · 17:24 UTC#8
no and i bet that's the prob. right there, isn't it?
Posted Feb 12, 2009 · 19:34 UTC#9
i guess that wasn't it. i don't know what's wrong. i tried to reset it and now it's saying i'm in cali. when i live in va.
Posted Feb 12, 2009 · 20:43 UTC#10
Sounds like you're not getting good GPS reception so either its in a bad spot or you have a bad antenna. You can check how many sats its picking up in the connection status screen
Posted Feb 12, 2009 · 20:49 UTC#11
how do i do that? i had a d3 in my suv and it worked. i don't understand. it shows my car turning but in same spot.
Posted Feb 12, 2009 · 20:51 UTC#12
Go into the connection status screen and look at it. How many sats are you picking up? Pull out of the garage before checking
Posted Feb 12, 2009 · 20:57 UTC#13
i'm new to this, how do i get there? thanks
Posted Feb 12, 2009 · 21:42 UTC#14
Its in the nav menu. Take a look, some useful stuff in there
Posted Feb 12, 2009 · 22:02 UTC#15
ok, i'll try that and see what i got. i hit the reset earlier and now it's reading that i'm in the right place, but just not moving anywhere when i go for a ride, it shows that i'm still at home. i don't need to hook up the vss wire do i? i never had it hooked up on my old d3 and it worked good. thanks
Posted Feb 12, 2009 · 22:39 UTC#16
spped pulse-0....antenna ok with 4 towers lit up..... back signal low...
Posted Feb 13, 2009 · 09:08 UTC#17
You should have more satellites than that. Is the ant. kinked or cut along the way?
Posted Feb 13, 2009 · 15:33 UTC#18
i'll check. i'd like to hide the antenna up inside the dash where it can't be seen like i did with the one on my d3 i had. this one don't seen to want to work without it being on top of the car. i had it working pretty good while on top of the car.
Posted Feb 13, 2009 · 18:36 UTC#19
Maybe your antenna went bad. Happens
Posted Feb 13, 2009 · 20:51 UTC#20
it's working now, but does the n2 show all road names and how do you get it to show gas stations and other places on map? thank you all for the help.
Posted Feb 13, 2009 · 21:18 UTC#21
Gas stations are under Overlay POI in the manual
Posted Feb 13, 2009 · 21:34 UTC#22
i got this unit without manual. i'll look on website. thanks
