F350 d3
By 06f350avicd3 · Feb 08, 2009in Problems/Troubleshooting💬 7 posts👁️ 1,081 views
Posted Feb 08, 2009 · 00:31 UTC#1
i recently installed a avic D3 in my f350 without the gps antenna (it was in the mail) and did the bypass as stated in the sticky. it worked great, untill i installed my gps antenna, now when moving about 5mph, the sound still works but the screen says no video while driving or whatever. does this mean the bypass did not work? aslo, does anyone know where the vss on a 2006 f350 is?
thanks alot...
Posted Feb 09, 2009 · 00:50 UTC#2
really? no one knows?
Posted Feb 09, 2009 · 00:56 UTC#3
i will get the vss location when i go to work in an hour.. you will have it tonight
Posted Feb 09, 2009 · 01:38 UTC#4
thanks alot sp4rt4n, but does anyone know if my bypass didnt work?? it worked fine before i installed my GPS antenna....
Posted Feb 09, 2009 · 02:14 UTC#5
does it give you a parking brake must be applied message?
Posted Feb 09, 2009 · 02:40 UTC#6
no, the video will work when sitting still, but when i move approximatly 5mph the screen goes dark and a message says something like "watching video while driving is illegal" or something like that....then when i stop it goes away, the sound from the video works the whole time...
Posted Feb 09, 2009 · 04:09 UTC#7
yup your bypass didnt work
as for the vss
grey/black radio harness or abs module, pin 21
the ABS module is in the driver rear corner of the engine compartment
