F90 cant process all the info???
By shaft412412 · Feb 08, 2009in Problems/Troubleshooting💬 9 posts👁️ 974 views
Posted Feb 08, 2009 · 16:25 UTC#1
whenever i have a destination set in navigation, all AV Sources skip or lag behind. its really frustrating to listen to music when it skips every 5 seconds. this problem does not happen when the navigation is not being used. anyone else suffer this problem or have any ideas?
Posted Feb 09, 2009 · 22:35 UTC#2
to add to this. i Found when i go to the sound settings and move the slidebars for the volume, it will cause the same sound skipping noise while the ipod is playing. what would be causing this?
Posted Feb 09, 2009 · 23:11 UTC#3
Resource limitations of the F-Series combined with too many requests.
Posted Feb 10, 2009 · 00:42 UTC#4
what would i do to stop this then? i havent even added my xm yet. how can it not run what its suppose to?
Posted Feb 10, 2009 · 00:55 UTC#5
Is it really skipping, or is it being muted to read navigation instructions?
With all the mods I have, including some processor-intensive ones (full building display), I hear no skipping when navigating...
Posted Feb 10, 2009 · 01:02 UTC#6
try the reset button... see if that helps. the only time i get or can duplicate a lag is playing divix off the sd card
Posted Feb 10, 2009 · 02:05 UTC#7
it really sounds like a skip.. it doesnt last long enough to be muted for navigation instructions. plus i have all the volumes for that set to zero. i'll try resetting it tomorrow
Posted Feb 10, 2009 · 03:13 UTC#8
Return it and purchase something else.
Posted Feb 10, 2009 · 04:11 UTC#9
Hmmm... it will mute music even if voice volume is at zero,though. Try turning AV source to off, then in system settings you can change muting from mute to normal. Turn music back and and see if it still skips. If it does, you probably have a bad unit...
