Broken yellow wire
By NOCUTENICK · Feb 09, 2009in Problems/Troubleshooting💬 4 posts👁️ 842 views
Posted Feb 09, 2009 · 04:09 UTC#1
anyone know what can i do if the yellow wire isint connecting into the plug? when i did the bypass, i think its not connecting good enough, cause the reverse cam isint working. Any help would be great. or where i can find a replacement white harness. Thanx in advance
Posted Feb 09, 2009 · 04:22 UTC#2
Irrelevant. Can you watch a movie or use nav options while driving? Then your bypass is fine. The problem lies somewhere in the camera and/or your camera wiring.
Posted Feb 10, 2009 · 03:10 UTC#3
The camera works fine when i go to the (rearview camera) settings. it just doesent click over to reverse cam when i go into reverse. and yes i can watch movies, and navi when driving. i have the positive from the reverse light going to the purple wire, and it also powers the reverse cam ( grounded in the back by the camera. )soo it turns on when i go into reverse . Thanx again
Posted Mar 26, 2009 · 18:42 UTC#4
You need to connect the camera trigger wire behind the radio to the reverse light positive wire side. Go to your menue and select battery not ground. Reboot radio. The radio should now go into the reverse camera mode automatically.
