Adding IP-Bus connection to F900BT EU Unit
By magga · Feb 09, 2009in Hacks/Mods💬 2 posts👁️ 978 views
Posted Feb 09, 2009 · 10:54 UTC#1
Hi all,
As you may or may not know, the EU version of the F900BT does not have an IP-Bus connection.
This is quite annoying as a have a Pioneer Digital Radio Tuner that I used on my old AVIC-D3 which I really want to use on this unit but it uses the IP-Bus connection.
As the US version of this unit has the IP-Bus connection, and the EU one doesn't but has the little gap where the connector fits, what do you think the possibility of adding this connection is? I would guess the board inside the two units are identical.
I might be willing to give this a try! If it works, it will open up a load of possiblities for EU users such as ability to add CD Changer, DVD Changer, DAB Tuner, TV Tuner and basically anything else that uses the Pioneer IP-Bus system.
Posted Feb 10, 2009 · 11:49 UTC#2
no one?
